I have a Dell Inspiron 5559 laptop, which is a little more than 3 years old now. A few months ago, the screen broke, and I replaced it myself. More recently, the new screen also became damaged after the laptop fell a few feet. The screen is now so dark that it is unusable. However, when I hold 'D' while starting the computer to display a series of colors, the screen is just as bright as it should be. Because of this, I'm not sure if I do need to replace the screen again.
A short while after the new screen became damaged, the laptop stopped turning on correctly. When I attempt to turn it on now, the "Battery Charging" indicator blinks white 7 times, then orange 2 times, then repeats. The fans do not turn on during this. I would like to know if this problem will go away if I replace the screen, or it requires a separate fix, and if so, what that fix is.
If anyone can answer these questions, please do. Your help would be greatly appreciated.
