Dell L400 CMOS battery replacement
  • Thread starter Thread starter Guest
  • Start date Start date
  • Tags Tags
    Cars
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Does anyone know where the CMOS battery is located in a Dell L400 laptop?
The laptop will not keep the clock or date accurate if it is unplugged. I
received a replacement battery from Dell, but it has no instructions at all.
There are no doors on the underside of the laptop and I hate to start taking
out screws and try to take it apart and put it back together.
Thanks for any help you can give.
Karl
"Silverado" <eltzroth@swbell.net> wrote in message
news:h9Qrd.40363$Al3.35816@newssvr30.news.prodigy.com...
> all. There are no doors on the underside of the laptop and I hate to start
> taking out screws and try to take it apart and put it back together.
> Karl
There's little or no documentation on the Dell support site for reaching
this battery.
So I googled it. Came up with this site (which shows photos of the battery
removal/disconnect for reasons I won't get into), but does show step-by-step
of how to disassemble the system in order to replace the battery:
http://qasimtoep.tripod.com/dell/pro_l400.html
Good luck. I can hardly endorse the information, but I'd use it if I were
in your shoes.
Stew
Thanks Stew, I'll give it a try and let everyone know.
Karl
"S.Lewis" <stew1960@cover.bellsouth.net> wrote in message
news:2CQrd.21774$Ch2.20989@bignews5.bellsouth.net...
>> I received a replacement battery from Dell, but it has no instructions at
>> start taking out screws and try to take it apart and put it back
>> together.
>> Karl
> this battery.
> battery removal/disconnect for reasons I won't get into), but does show
> step-by-step of how to disassemble the system in order to replace the
> battery:
> in your shoes.
> Stew
Look at doc for the Latitude LS or Inspiron 2100. They use the same case.
Tom
news:eqbsd.26784$fC4.4756@newssvr11.news.prodigy.com...
> Karl
>>> laptop? The laptop will not keep the clock or date accurate if it is
>>> unplugged. I received a replacement battery from Dell, but it has no
>>> instructions at all. There are no doors on the underside of the laptop
>>> and I hate to start taking out screws and try to take it apart and put
>>> it back together.
>>> Karl
>> this battery.
>> battery:
>> were in your shoes.
>> Stew
OK boys and girls this is the secret, Dell dose not call it a CMOS battery and it does not look like a CMOS, battery it is called a reserve battery it is under the key board and it looks like 3 small battery's bound together and it will be green. It unplugs to replace it.
And I did not Googled it I Yahoo-ed it.
I am speaking of a Dell Latitude L400
DELL LATITUDE L400 C400 Reserve CMOS Battery 3E158
Hello! Hey, We have common problem, but mine was one year ago. Maybe this battery replacement might help you, http://www.laptopplus.com.au/. I had a good experience with their services.
