Dell Optiplex 330 not booting into any operating system, any help greatly appreciated.
Hi,
I have a Dell Optiplex 330 with a Core 2 Duo at 2.8GHZ, 2GB DDR2 666MHZ, and a 120GB Sata Hard Drive.
It previously did not have any OS on it, just booted to bios screen. I tried installing Windows 10 and it gave me the error "whea uncorrectable error". I couldn't find a solution to this, and even after updating the bios to the latest one, it still wouldn't work.
Then I tried Windows 7 and Linux mint, in 32 and 64 bit, none worked. I have seen many Optiplex 330s with Windows 10 so I know it's not a compatibility issue. I have messed around in the bios and turned off 'fast boot' etc but no difference.
Any help in solving this problem would be greatly appreciated.
Dylan.
Sep 18, 2017
[quotemsg=20645066,0,1404079]That error should be related to Windows only. Linux mint should load fine. Do you remember what error occured when you attempted to install it?[/quotemsg]
Linux Mint crashed on installation as well. You know where it says automatic boot in [x] seconds? After it did that, the screen went black and nothing happened. Same with everything I've tried.
Sep 18, 2017
[quotemsg=20645181,0,1404079]Give it another shot. The laptop is a prime candidate for Linux. What method do you use to load the ISO onto the USB drive?[/quotemsg]
Ok, tried Linux Mint a few times now, booting off CD and USB and it still won't work. This isn't an issue with Linux or Windows I think its the pc
SirSub42
367
Here are a couple of boot time options you can try
https://neosmart.net/wiki/0x0000124-whea-uncorrectable-error/
I misread the original error. Apparently it can involve a misconfiguration of your BIOS< which certainly would impact linux mint.
Sep 18, 2017
[quotemsg=20645348,0,1404079]Here are a couple of boot time options you can try
I misread the original error. Apparently it can involve a misconfiguration of your BIOS< which certainly would impact linux mint.[/quotemsg]
Thanks for finding me that article. Spent a few hours today swapping out all the components trying to find one that was faulty, and reset the bios and tried changing certain settings, still won't work. I'll either order a new motherboard or just give up on it now.
Thanks anyway for all the help.
Reactions: rstaccntunknown3
Jun 3, 2023
I am currently having this issue. I also believe it is the motherboard as I ran the troubleshoot, and sometimes the GPU or ram fails even though im using the integrated graphics and not the gpu and have swapped out the ram, I still get errors. Thinking it has to do with the ram modules on the board dim slots I believe that is what they are called. Did you ever experiment with the new board? Thanks in advance!
USAFRet
Please start a NEW thread for your particular situation.
This one is 5 years old.
Thanks.
