ryan27968 :
Skywalker7 :
ok,I've done it...but HW monitor still doesn't allows me to change anything!!And I've register,HDD temp is 40C....is that to high cause I'm just using internet?
you will not be able to change anything. your pc is too old. you need a newer pc to be able to change fan speed. 40 degrees is perfectly fine for a hard drive.
I was able to so this with speedfan with no problem! I just went into options and stumbled upon a checkbox that allows for compatibility with not only dell notebooks as the checkbox claims...it works across almost every dell computer, desktop OR laptop! Even though my speedfan is too messed up to use the CPU fan any more, and i am too lazy to re-install speedfan, it worked up until i had to re-install my O.S. without any problems.
