Dell Optiplex 9010 PCI-E Watt Limit?
Shlutka
339
Bought a system and plan on upgrading the PSU / GPU. Here is a pic with the specs posted in the title.
https://i.imgur.com/SFGK1SL.png
1) Do you think this was a good deal?
2) I've heard that in alot of Dell Optiplex's, the motherboard's PCI-E slot only supports up to 35 watts (Dell Optiplex 960/990, etc). Is this the same case with the Optiplex 9010? There is no information on the specific motherboard it is using.
Assuming I upgrade the power supply, and use a card that is powered by the PSU, will I run into any issues?
Also, if the card does not fit I plan on just using a different case.
It should, but you'd have to make sure the PSU could fit in that case if you're holding onto it.
There are alot of threads / videos explaining that Dell has a 35 watt limit on the PCI slot for some of the Optiplex builds.
https://www.youtube.com/watch?v=TlXLN0sxZMk
But assuming I upgraded the PSU and used a card which requires PSU power, would that problem not occur?
On page 55-57 of the manual there is no mention of any PCIe slot power limit. You should be good to go.
https://data.technimax.cz/attach/artilky/Dell-OptiPlex-9010-SFF-Owners-Manual.pdf
There was a Dell SFF 275W PSU back in the Pentium 4 days.
https://www.discountelectronics.com/dell-optiplex-740-745-xps-210-sff-power-supply-kh620/?gclid=CjwKCAjwjIHeBRAnEiwAhYT2h5TU8m9UAitzDJHQCAAFGku-_bqgvx_8_sv3m2NFC2gTE6lTLOi17hoCEf8QAvD_BwE
Note it only has 1 SATA, with a Molex 4 pin , and FDD
EVGA list s a 650W SFX PSU but IIDK if it's confirmed in a Dell SFF.
There is always a PCIe power limit, it's not like it'll just deliver whatever you want it to. Like OP said, there are plenty of threads and videos explaining that the limit is 35W.
If it is limited it should be stenciled on the MB next to the PCIe 16x slot. Some have it some don't. The normal limit is 75W which won't be stenciled, or mentioned in the manual because it's the default PCIe 16x limit. Many people report success ignoring the limit, but that's up to the individual if they want to try that.
Wouldn't the Watt limit only be an issue if the GPU is powered only by the motherboard? Is it a 35 watt input or output limit?
