dell optiplex gx620 (desktop model):can i upgrade my power supply?please....
acip__
17
hi,guys,i have a pc dell gx620 desktop model,so, i want to upgrade my power supply to a standard 500w power supply,is it possible?
if you have a ruler AND know how to use it, you can simply measure the space and compare it against any modern ATX power supply and see if it can fit. nearly all of the connectors are standardized (24pin, 4/8pin, sata, molex, etc) so it really is just you and a ruler.
The Dell OptiPlex GX620 DT uses a custom form factor power supply unit:
OP. There is a totally different solution. The card you have selected, and a new PSU plus all the hassle cost a decent amount.
If you get a GTX750ti that will fit in your system and does not require additional PCI-e power feeds, it will work well off your existing 305W PSU; plug-and-play.
