Directory of C:\Users\randa\Downloads\LSIUtil_1.62\Windows
07/30/2022 08:59 AM <DIR> .
07/30/2022 08:59 AM <DIR> ..
07/30/2022 08:59 AM 352,768 LSIUtil.exe
07/30/2022 08:59 AM 556,544 LSIUtil_amd64.exe
07/30/2022 08:59 AM 789,504 LSIUtil_ia64.exe
3 File(s) 1,698,816 bytes
2 Dir(s) 314,352,480,256 bytes free
C:\Users\randa\Downloads\LSIUtil_1.62\Windows>LSIUtil.exe
LSI Logic MPT Configuration Utility, Version 1.62, January 14, 2009
1 MPT Port found
Port Name Chip Vendor/Type/Rev MPT Rev Firmware Rev IOC
1. Scsi Port 0 LSI Logic SAS1068E B3 105 00192f00 0
Select a device: [1-1 or 0 to quit] 1
1. Identify firmware, BIOS, and/or FCode
2. Download firmware (update the FLASH)
4. Download/erase BIOS and/or FCode (update the FLASH)
8. Scan for devices
10. Change IOC settings (interrupt coalescing)
13. Change SAS IO Unit settings
16. Display attached devices
20. Diagnostics
21. RAID actions
22. Reset bus
23. Reset target
42. Display operating system names for devices
45. Concatenate SAS firmware and NVDATA files
59. Dump PCI config space
60. Show non-default settings
61. Restore default settings
66. Show SAS discovery errors
69. Show board manufacturing information
97. Reset SAS link, HARD RESET
98. Reset SAS link
99. Reset port
e Enable expert mode in menus
p Enable paged mode
w Enable logging
Main menu, select an option: [1-99 or e/p/w or 0 to quit] 13
SATA Maximum Queue Depth: [0 to 255, default is 8]
Device Missing Report Delay: [0 to 2047, default is 0]
Device Missing I/O Delay: [0 to 255, default is 0]
PhyNum Link MinRate MaxRate Initiator Target Port
0 Enabled 3.0 3.0 Enabled Disabled Auto
1 Enabled 3.0 3.0 Enabled Disabled Auto
2 Enabled 3.0 3.0 Enabled Disabled Auto
3 Enabled 3.0 3.0 Enabled Disabled Auto
4 Enabled 3.0 3.0 Enabled Disabled Auto
5 Enabled 3.0 3.0 Enabled Disabled Auto
6 Enabled 3.0 3.0 Enabled Disabled Auto
7 Enabled 3.0 3.0 Enabled Disabled Auto
Select a Phy: [0-7, 8=AllPhys, RETURN to quit]
