Frozen Fractal :
photonboy :
I game on an IPS, 1440p (16x9), 60Hz monitor and don't get stutter or artifacts. The response time of 5ms is fairly good and while it won't prevent blur it is better than mine and i rarely notice blur.
60Hz is definitely suitable for gaming. maybe not IDEAL, but I'm pretty sure there are millions of people (including those on HDTV's) that handle 60Hz just fine.
That maybe because your GPU don't overkill 60FPS, but yeah, it isn't ideal, but decent for gaming.
Not sure what your point is, but mine is that you were saying 60Hz is not suitable for gaming which is nonsense. Probably 98% of the world is gaming on 60Hz screens. All HDTV's have 60Hz inputs (even for "120Hz/240Hz" HDTV's as that is motion smoothing of the input but not suitable for gaming anyway).
And you don't get STUTTER or ARTIFACTS due to the refresh rate of the monitor. You get stutter if the game is coded badly or you run VSYNC ON and drop below the refresh rate (i.e. 59FPS or below at 60Hz). Artifacts have multiple causes including bad code and defective memory but not because it's a 60Hz monitor.
It's a GREAT monitor for gaming, and far better than most people have. However, the cost is high because it's designed for professionals with different needs.
The best monitor thus far for gaming is probably the Acer Predator (GSYNC, 2560x1440, 4ms, IPS).
