O orangegasm Reputable Mar 29, 2014 21 0 4,520 Mar 31, 2014 #1 I am trying to make a new computer and I have sort of reached my allotment for the price. Is it possible to move the XPS 8500 wifi card and DVD Drive to New PC. I am using Windows 8.1 for it by the way.
Solution Ubrales Mar 31, 2014 orangegasm : And where would I find the drivers? Two ways. One from the manufacturer's website and the other from Windows. Windows may install the correct driver. Try it.
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Mar 31, 2014 #2 Yes for the DVD drive. Maybe for the wifi card IF you can find the proper drivers. Upvote 0 Downvote
Ubrales Polypheme Dec 3, 2009 13,240 11 61,465 Mar 31, 2014 #3 If they fit they will be ok. I see no problems! Upvote 0 Downvote
O orangegasm Reputable Mar 29, 2014 21 0 4,520 Mar 31, 2014 #4 And where would I find the drivers? Upvote 0 Downvote
Ubrales Polypheme Dec 3, 2009 13,240 11 61,465 Mar 31, 2014 Solution #5 orangegasm : And where would I find the drivers? Two ways. One from the manufacturer's website and the other from Windows. Windows may install the correct driver. Try it. Upvote 0 Downvote Solution
O orangegasm Reputable Mar 29, 2014 21 0 4,520 Mar 31, 2014 #6 Okay. Sounds good! Thanks! Upvote 0 Downvote
