Hi,
My laptop was heating up a bit too much (temperature above 90’s in normal load, and sometimes shutting down after hitting 100C), so I finally decided to open up my Dell XPS 15 (L502X) and replace the thermal paste. I have few questions:
When I opened it up, apart from the thermal paste on the cpu (i7-2630QM) and gpu (Nvidia GT-540 2gb), there were several white pads, and one grey pad. The grey pad was above the motherboard HM67 chip. This is the first time I ever saw a heat sink with thermal pad needed to cool down the motherboard. Or am I missing something? And what are all these small white pads? They seem to be covering different chips on the motherboard. Does anyone know the width of these white pads, and grey pads? Are all of these thermal pads to conduct heat? Or some are meant to block heat? I think the white ones are meant to block health, but I may be wrong.
Anyhow, after replacing the thermal paste (didn’t do anything with the pads, since I wasn’t expecting to see them anyway), the temperature of CPU and motherboard remains in 70’s C, and GPU in 60’s C under normal load (20 browser tabs, and some MS Office work alongside). But the fan works in an annoying manner with bursts of sounds, instead of constant sound. It is rather annoying, and I rather have the fan working the whole time than this annoying bursts. Any solution to fix this?
I am also considering downgrading to I5-2540M (lower TDP, and dual core), but its not worth it if the fan is going to behave in similar manner.
