Hi
My GPU is dying... its done well - its very old!
Can anybody PLEASE help me with suggestions for a replacement GPU & PSU if required.
I've never upgraded anything in a PC - but I'm happy to give it a go 🙂
I'm not a big gamer, office & photo work, but my kids use: Steam (Heros & Generals, Planet Coaster, Team Fortress 2 etc), Roblox & Minecraft, Elite Dangerous (Horizons). Most of the gaming is on the xBox or NES Switch. I just want to keep it the PC going as long as I can without buying a new one. As the GPU is old, I'm hoping & assuming I can get a much better card - BUT, my H/W is old, so want to make sure it fits and it works with my old system:
Stock Dell XPS8700, no changes at all. [32gb RAM, i7 4790 (3.6 GHz)]
GPU: AMD Radeon(TM) R9 270
PSU: 460W
Ideally, as I'm no techy, I would prefer an easy fix, without having to change too much. I don't really want to be messing with anything else S/W or H/W unless super easy.
1. GPU only
OR
2. GPU & PSU only (if easy, and I get a much better card for the money)
I found this post, suggesting the GTX 1660
www.dell.com
"GTX 1660 should work if bios is updated to current. Non Dell cards will require secure boot OFF."
"bios update with secure boot OFF" What does that actually mean? Is it easy to update? Another post said, get it wrong and your system is DEAD!
Another post said confirmed 1660 would not work without the BIAS update above, and said a 1050Ti would work ok.
www.dell.com
GeForce GTX 1050 Ti I should be fine. Newer card like 1650 might require bios update.
OR based on my limited knowledge...
Should I be looking at Radeon 570 or 580 ? But not really sure if my stock PSU can handle either of them OR if I can just plug one of them in and all good. Same Bias upgrade issues? I really have no idea and could do with some help please.
As above, can anybody PLEASE help me with the above?
Thank you in advance for reading, and for any help.
PSU: 460W
1. GPU only
OR
Re: XPS 8700 CURRENT GPU UPGRADES
it depends what your future plan is. do you plan to stay put w i7-4790, upgrade to 4790k on the same motherboard, upgrade to 8900 motherboard in the same case, or move to a whole new machine? buying a faster gpu gives you some future proof, although the future horizon is always moving. based...
XPS 8700, GeForce GTX 750 Ti, GPU upgrade?
Hello, I have a DELL XPS 8700. I would like to upgrade my NVIDIA GeForce GTX 750Ti 2GB DDR5 graphics card to a better one which I can just remove and replace with the new one with the existing set up I have. The specs of the my DELL XPS 8700 are as follows: 4th Generation Intel(R) Core(TM)...
