delta-homes toolbar/engine installed by itself
d1versify
793
hello. i searched in google how to remove this thing, but each site told me to download different software.they didnt look ok so i didnt.
I also checked the extensions tab and control panel and nothing there.
What is the real way to remove this? IT has screwed my pc up.
http://malwaretips.com/blogs/delta-toolbar-virus/
If you don't want to download any software, you can do steps 1-2. Then follow this guide to clean up the registry. Always be careful when messing with the registry.
Blume12
Hello. The first and the best way to remove it -is to back up your computer. You can also try the Spyhunter:http://nabzsoftware.com/types-of-threats/delta-homes, but it kosts.My personal recommendation would be to remove the program and replace it with a trustworthy alternative such as Malwarebytes Anti-Malware or Emsisoft Anti-Malware or to use ADWcleaner. Regards from Amsterdam
cnunuoma
You allowed it to install, by letting some application use its default setting.
Jwpmbu
