News DeskPi Pro Raspberry Pi 4 Case Features a 2.5" SATA Drive Bay
Can we get a confirmation on UASP support? I assume this is the case, but it's not listed in the specs anywhere.
DeskPi Pro Raspberry Pi 4 Case - a beautiful and robust case. Many features including large heatsink, full sized HDMI ports.
One problem: I instilled a Pi 4 8g an SSD, and everything worked on the test bench. However, when I went to install the DeskPi in the media room, the monitors would not connect. Everything I tried didn't work. I then took it back to the test bench with the monitor, etc. and it worked. The monitor is a DVI with an adapter. I then tried a different Pi 4 and the media room monitors worked.
The long and short of it is, the DeskPi Pro cannot function with cables longer than 6 ft. Also, HDMI to VGA converters don't with the case. Multiple monitor HDMI switch boxes also don't work.
