Question Desktop Audio Setup Additions - Questions
septune
21
4
515
I have a pair of Micca RB42 speakers for my PC that are powered by a stereo amplifier, to the green audio port. I'm wondering, if I wanted to add a center channel speaker, a Micca RB42-C, powered by a second, mono amplifier, would it be as simple as plugging the line-in from the amplifier to the orange audio port to get it working? Secondly, since from what I understand, this orange port is used for either a center channel speaker or a subwoofer, would this limit me from adding a subwoofer in the future? I've never actually used anything other than the green port for audio on a PC before.
Update your post to include the applicable make and model information for all devices/components.
Also include full hardware specs and OS information for your PC.
The motherboard's I/O panel ports and connected front panel/case ports being of most interest.
And you must consider the connectivity and standards being used (TS, TRS, TRRS).
FYI:
https://www.cablechick.com.au/blog/understanding-trrs-and-audio-jacks/
Understanding what is available and configurable for use is the starting point.
The ports are all 2 channel ports so the orange port is both center channel and subwoofer. You would need a splitter, similar to a left - right splitter, to split the orange port between the center and subwoofer.
Reactions: septune
Okay perfect, thanks for the info.
