I am currently paying for 1Gbps internet. However, on my Desktop PC, I am only receiving less than 100 Mbps. On my HTPC I am showing speeds of 700 Mbps on Speedtest and am getting dL speeds of 200-300 Mbps usually.....I'm not sure what is the problem here. I also got a new router for the 1gbps connection. Any help is appreciated
tried upgrading to CAT 8 cabling as well...currently CAT 6.... no change.
both connections are wired directly to the router.
Here are my DESKTOP specs:
CPU: Intel core i7-6700K @4.00GHz
MB: ASUSTeK COMPUTER INC. Z170 PRO GAMING
GPU: GeForce GTX 1060 6 GB
HDD: Samsumg SSD 850 EVO 250GB
Router: TP-Link AC2300 Wireless WiFi Router | Powerful 1.8GHz Dual-Core Processor, MU-MIMO (Archer C2300)
ookla speed test results for DESKTOP PC
https://www.speedtest.net/result/8521624425
Here are my HTPC specs:
CPU: AMD Ryzen 5 2600X
MB: MSI B350M MORTAR (MS-7A37)
GPU: GeForce RTX 2080 Ti
HDD: WD Blue 3D NAND 1TB PC SSD - SATA III 6 Gb/s, M.2 2280
ookla speed test results for HTPC
https://www.speedtest.net/result/8521626669
