It's a self-built computer, I'll give you hopefully necessary details:
ISP: Utility Warehouse
Connection Type: Unsure
Router: Technicolor TG582N
MOBO: AS-Rock H81M-DGS R2.0
PSU: XFX - 550W Core Edition 80+ Bronze
OS: Windows 7, I think my drivers are up to date...I think.
Netgear N300 Mini Usb Wifi Adaptor
Hopefully that's the required information, so here's the problem.
I live in a block of flats, top floor. My room initially was a dead zone, so I bought a TP-Link wifi range extender so I could connect to our router. My phone gets 5 bars and so does my desktop, but my desktop only reaches 0.3-0.4 MBP/S, when it should be hitting 8-15ish and my phone hits around 6.
I took my desktop through to the room with the router and plugged it directly into the router via Ethernet cable. It had a burst of 8MBP/S (online speed test). Then I tested the wifi, while still plugged into the router, and it went back down to 0.3MBP/S, so I took out the adaptor, re-tested the connection with the Ethernet cable and still 0.3MBP/S. I've tested my speeds when no-one else has been connected but me, so just 1 other device, yet still 0.3MBP/S. I'm losing my stuff here guys and need some serious help. All other devices work PERFECTLY, we have multiple consoles able to play simultaneously with very little lag.
I recently moved to this flat for university, but when I was living at home and in my previous flat, this same computer experienced no issues like this.
Anyway, thanks to whoever helps me
