Desktop Internet connection problem (internet goes slow after around 30 mins or 1 hour)
Saiemp
4
So when I use or not use my desktop a "while" (such as just leave it there turn on/using it around 30 min or 1 hour later~) my desktops intent will go really slow! if I restart it.. it will goes back to normal again.. and after 30min or 1 hours later .. it goes slow again ... can anyone help me? if they know how to fix this problem
Well I bought this new desktop at 02 of July 2014
NETcard: Gigabyte Exclusive Latest WIFI wireless 802.11AC dual band
CPU : Intel New Haswell Core i5 - 4690 3.5 GHz 6MB
MB: Gigabyte Ga-H97 - HD3 Socket 1150, Intel H91 Chipest ATX Form
RAM: G.Skill Ripjaws X 8GB DDR3 1866Mhz (PC3 14900) ultra
Graphic card: EVGA GeForce GTX770 SC versionwith ACX Dual Fan, 2GB GDDR5
PSU: Cooler Master V-series 700 Gold 700w 80 plus Gold ATX PSU Active
This sounds like it is due to overheating of the WiFi module. You can try to put a fan on the computer, and run it with the case open to see if it helps. I have had to rotate WiFi adapters to keep a connection when they kept overheating.
like after 30 min when I try to use google chrome to see my facebook it loads really slow !! and when I restart the computers it all works fine again .. the other computers all works fine
oh okay that might be overheating .. I will give it try ! thank you!
i understand that it loads the page slow I was asking if other functions are slow too like programs loading slower or program windows minimizing or maximizing slower, could be a cpu getting hot slowing whole system down or a possible ram problem. When you restart the computer does it take the same time to get slow or does it happen faster right after a restart
the other functions are all works fine! just the internet is slow! minimizing or maximizing is all works as normal speed ... and when I restart the computer it just take the same time / or maybe faster?! I didnt check that but im sure it just restart at normal speed..
