Desktop PC problems
nikospc
287
Hi, how can i pinpoint what is wrong with my PC, especially when I get no screen, is it obviously the graphics card? or is it from the HDD not boting up? Is there some kind of equipment i can get in order to connect it to my PC somehow and pinpoint which component is at fault?????
It sounds like your PC is failing to post, which is typically a CPU-Related issue. Make sure the two cables from the PSU are plugged all the way in and all parts are secure.
it is true i get no beep. took graphics card out and pluged it in another pc and worked,, is there any way to tell if the graphics socket on the m/b is failing???? will check CPU as sson as possible
I know it's been a while, but has your issue been resolved?
