Hey guys starting a few days ago, a friend's desktop work computer started randomly restarting with horizontal lines going across the screen on reboot (pic: https://imgur.com/Vq9wvuZ) There is nothing stressing the hardware (no games video, or anything requiring fast CPU/memory). Basically the only thing being done on this computer is excel documents and outlook. I haven't been able to replicate the issue but I'm not able to get to the office to troubleshoot there so I need to resolve the issue while the computer is at my place if possible.
EDIT: The issue just started happening for me at home. The computer will randomly restart but will fail to reboot 3-5 times. It will start the reboot but then power off again and the restart process starts up again and then 1-2 seconds after it will restart again until after 3-5 tries it boots up into windows. The artifacts on the screen change from horizontal lines to colored blocks and everything in between. Also, the monitor light turns to orange and then back to blue when rebooting. The monitor power light never disappears. Thanks for the help!
Computer details:
Windows 7 64 bit
Powerspec maker, all stock components
Intel i3-4340 CPU @ 3.6 GHz
4 GB single stick ram
Display adapter: Intel HD graphics 4600
Troubleshooting completed:
Moved computer to my house
Different power strip
Cleaned dust out
Reseated all cables to motherboard, power supply, and monitor
Successfully completed windows memory diagnostic twice
Ran a good 2-3 hours of Furmark GPU test with no errors
Turned off windows automatic updating (it was on before)
Event log critical error copied details:
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 2
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2018-03-05T19:26:08.624035300Z
EventRecordID 309000
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer WHF-Sheri-DT.WOODHILL.local
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress false
PowerButtonTimestamp 0
Computer details:
Windows 7 64 bit
Cleaned dust out
- System
- Provider
EventID 41
Version 2
Level 1
Task 63
Opcode 0
- TimeCreated
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
