Hello all.
This is my first post here and I'm hoping you knowledgeable folk can give me some useful advice as it is getting to that time for me where I am looking to get a new laptop.
This will be my second laptop and I feel that the 3 years of use which that £500 purchase has given me are sufficient enough and it is time to move on to a more powerful machine that will cost more but perform better and last longer doing the things I want it to do (current one struggles past moderate web browsing).
I will want this new laptop to cope with multi-tasking and fairly intensive web browsing with sometimes 50+ static page tabs open. I am also a big fan of (and have a quite a lot of!) music and would like my new machine to serve as a good multi-media system for entertainment with good sound capabilities etc.
I used to play games on a desktop several years ago (around the time of Crysis, Battlefield 2 etc.) and I now again would like to start being able to play games well also, even recent ones. Even if not at maxed out settings with full AA at an enthusiast level and large resolutions etc, I just want to be able to play new things like Crysis 3, Battlefield 4 at a level where they run smoothly whilst looking good for a reasonably priced piece of graphics hardware! By looking good, I simply mean at high-ish settings with reasonable reductions here and there of course at moderate native resolution - just not everything near minimum and pixelated to hell purely to be able to get playable Frames Per Second! I have been out of gaming a long while and never on a laptop.
In short, I am very much looking at a multi-functional Desktop Replacement Laptop and below is the hardware I am currently considering:
17.3" FHD 16:9 "Matte Type" Super Clear Ultra Bright LED Anti-Glare Screen (1920x1080)
4th Generation Intel® Haswell Core™ i7-4700MQ (2.4GHz - 3.4GHz, 6MB Intel® Smart Cache)
16GB - DDR3 1600MHz Dual Channel Memory (2 SODIMMS)
NVIDIA GeForce GTX 770M (3.0GB) GDDR5 PCI-Express DX11
Primary Hard Drive: 120GB Crucial M5 Series SSD [SSD2 - SATA III]
Secondary Hard Drive: 1TB 5400RPM [SATA II - 3GB/s]
6X Blu-Ray Reader + 8X DVDRW/CDRW Super Multi Combo Drive
IC Diamond Thermal Compound - CPU + GPU (Free Upgrade)
2x Integrated Dedicated Onkyo Front Speakers & 1x Integrated Subwoofer
Sound Blaster Compatible 3D Audio
Wireless: Intel Dual Band AC 7260 802.11 A/AC/B/G/N 2.4/5.0GHz + Bluetooth 4.0
Internal 9-in-1 Card Reader
Webcam: Integrated Digital Video Camera
Smart Li-ion Battery (8-Cell)
:: Total Cost $1473 // £882
- This set-up comes without an Operating System and only the Drivers for both Windows 7 & 8 and Utility Software. I assume purchasing and installing the Operating System myself shouldn't prove too difficult?
- For an additional $300 // £180, the NVIDIA GeForce GTX 780M is available or $100 // £60 Radeon AMD 8970M. Is this is a worthwhile addition for future-proofing and given my wish for moderate intensity gaming, or does the performance : value balance decrease with this upgrade?
Would I be able to upgrade to a superior graphics card myself at a later date - is it easy to exchange them or do not all models' sizes fit in laptops and/or is it difficult to do?
- I am not entirely sure how to configure and what to do with an SSD but I am sure it is a good idea for speed and performance from my research!
- I am definitely not wanting to go smaller than a 15.6" screen for various reasons including the keyboard size. Is it a recognised fact that the same hardware is always more expensive in a 15" chassis compared to a 17" one? I seem to find this to be the case everywhere.
Thank you for your time to read this and any advice.
Regards
Regards
