My Rig :
Intel i7-6700k
Gigabyte b1 sniper b7 motherboard rev 1.0
16gb DDR4 Kingston Fury
CM 600w PSU
MSI Nvidia GTX 750 ti 2GB DDR5
1 TB Seagate Barracuda HDD
Win 7 x64
This serious issuse started when I updated the BIOS of this system . Since the update, The OS always gets freezed at the "Starting Windows" Logo and after some frequent restarts , it used to boot. Once i forgot to switch off the system and it went to sleep.When i tried to wake it, a BSOD appeared and it crashed completely and i wasn't able to make it boot properly I tried all the options and it did'nt work .. I had to Reformat the Entire C drive and install a fresh installation . It was fine until a week ago , when it did froze again at the aforementioned point.
After going through some of the threads , i read this following thread :
http://www.tomshardware.com/forum/49996-63-window7-freezing-startup-statup-logo
The issue almost matched it to the one I faced . I followed the suggestions from the Forum and changed the BIOS options. Please have a look at the following image links :
1. https://drive.google.com/open?id=1_f-1Hu6WG-obwZSse82B-z3c9ODKJe7x
2. https://drive.google.com/open?id=11CkJjdfddnaUzh8Tq5uWVMYCU9k8IYJh
Changes Made [ Apart from the indicated arrows ] :
Disabled the SATA ports [ apart from the HDD and DVD -rw Port]
After changing the options in BIOS, i did'nt face any issues until today where ,The OS failed to boot. It showed a failed Boot setting and tried to restart and again the freeze issue happened. Then I booted into safe mode and copied a couple of files in case of worst case and then , finally at the 4th time i Booted up.
I looked at lot of issues and threads but none seemed to state a particular case of problem ..Please provide a resolution at the earliest.
Intel i7-6700k
CM 600w PSU
Win 7 x64
