Question Desktop speakers that plug into USB not audio jacks!
Oct 1, 2019
12
My computer does not have a big or little audio jack. Every thing I see online is you plug the little one into where the little hole is. Seriously is all it is, it works like headphones. My computer only has a USB port available. Can anyone suggest a speaker set that plugs into a USB port only like how a Logitech plug and play controller works?
attachment.php
what computer, what os
if your pc doesnt have headphone jacks must be a old office pc or a workstation, those need the install of a usb soundcard or dac, provide more details to know what will be best on your case
Thanks for answering this is what I got, comes with no speakers. I never heard of a monitor not having speakers! ..... OMEN by HP 32 Display .......... I get it now, it goes in the back of the tower, I thought it went into the monitor. I don't get it until tomorrow so I was confused. So the little speaker thing will go in the green hole? What are the red and blue holes?
only in the last 5 years i got monitors with audio output, a monitor with speakers usually sounds like crap, so you never use those stupid crappy speakers, you buy real headphones or some desktop speakers
connect your normal headphones or pc speakers in the back of the pc, as described previously by you, SmokeyDokey
the green one is the one that matters the most, the pink one is only useful if you are going to use headphones with a microphone
the blue connector is line in, can be used for another icrophone, or used also for some 5.1 speaker system, as a home theater, rarely used now that we have hdmi connectors
at the moment i am using logitech z523 speakers, great bass, not that great treble and mids
https://www.amazon.com/Logitech-Spe...?keywords=logitech+z523&qid=1575257394&sr=8-1
try to put more money on the speakers, go for these
https://www.amazon.com/Logitech-Z62...?keywords=logitech+z523&qid=1575257443&sr=8-2
perfect to peel off paint from the walls and make your neighbors hate you
if really all you can afford is 50 dollars for hte speakers, these looks nice
https://www.amazon.com/Logitech-Blu...1575257523&sprefix=logitech+2.,aps,260&sr=8-7
check reviews for any of these in youtube, see if something fits your needs
