Desktop System Monitor?
thehiddenlotus
192
I'm looking for a low resource application for Windows 7 that can reference pertinent system information such as CPU and GPU temps/usage, memory usage, etc.
I'm looking for something could always be running for easy reference like a desktop gadget.
I tried Google and didn't come up with much.
Any suggestions?
Thanks in Advance,
Luke
when i was using windows 7 i used a windows desktop gadget to monitor my gpu and cpu loads and temp
and when i wanted more details i just open up a monitoring software and keep it opened
for gpu monitoring i used to use GPU Monitor for Windows 7
http://www.windows7download.com/win7-gpu-monitor/mokttrar.html
and the System Control A1 for cpu load monitoring
http://pcsupport.about.com/od/toolsofthetrade/gr/system-control-a1-gadget.htm
CPUID provides some very good system monitoring softwares and for gpu you can get GPU-Z
http://www.cpuid.com/softwares.html
http://www.techpowerup.com/gpuz/
But do any of these show me cpu and gpu and memory info all in the same place/program?
