Question Desktop w/wired connection...connect via wifi too?
coyote2
56
My new desktop PC will be right next to my AX router, connected via ethernet. Should I even bother to enable my new mobo's AX and attach it's wifi antennae?
coyote2
56
Thank you very much for your reply, USAFRet!
What if I saturated my wired connection (I do have Gigabit fibre and might also be transferring files across my LAN)...would Windows use the wifi like a second 'lane' of extra bandwidth?
I guess there might also be value in other wireless devices skipping my router and connecting direct to the PC, but that doesn't interest me.
USAFRet
113,288
1,874
155,190
18,564
"would Windows use the wifi like a second 'lane' of extra bandwidth?"
No, it doesn't work like that.
Just leave the WiFi OFF on your desktop. You can't pair the two connections to the router.
