Desktop workstation build without need for GPU power
buggaby
82
Hello all,
Thanks in advance for any help.
I'm looking to build a desktop workstation to run work simulations. It's CPU intensive, so I won't be needing anything more than onboard-quality video (also, using Linux instead of Windows, so no gaming). I'm interested in the AMD Ryzen 7 series because it gives great parallelization for a good price, but it doesn't appear to come with onboard video. Maybe that difference wipes out the price gains over i7? There are older discrete cards for under $100. Do these compare with Intel onboard speeds?
If there is any advice about my build below, I'm happy to hear it! My budget is around $800 ideally, but can go to $1000 if needed. Right now the Ryzen 7 1700x is on sale at NewEgg for $190. I would also like 16GB RAM. Don't need Windows for this build, so I'll save a bit there. My current build plan is this, which prices out to about $730 +tax on NewEgg, but it's still missing the GPU:
CPU - AMD RYZEN 7 1700X
Motherboard - ASUS ROG STRIX B350-F
Memory - Corsair Vengeance LPX 8GB Memory Kit
Case - Corsair Carbide Series Clear 400C
Drive - GIGABYTE UD Pro 2.5" 256GB
Optical Drive - Asus Black SATA 24X DVDRW E-Green No Logo Model
PSU - EVGA SuperNOVA 650
CPU Cooler - Cooler Master Hyper 212 EVO - CPU Cooler with 120mm PWM Fan
Thanks!
Do you need an optical drive? I don't believe that the Corsair Carbide 400C has any external drive bays, so you would need a different case if you wanted it to hold one of those.
As for a basic video card, maybe go with something like a GT 710? Just don't expect much from GPU performance out of it, as it's actually below the performance of Intel's current integrated graphics, at least in terms of 3D performance.
https://pcpartpicker.com/products/video-card/#c=362&sort=price&page=1
I would disagree about cheaping out on the RAM to much for a Ryzen build though, as it will affect CPU performance. Ideally, you should look for around DDR4-3000 speed, and enable that higher speed via its XMP profile in the BIOS.
The regular 1700 or 2700 come with coolers so you could avoid the EVO. Make sure you get a matched set of DIMMs. Don't buy two single DIMMs of the same part number. Buy a two DIMM kit. You may be able to save money by getting 2400Mhz RAM instead of higher clocked.
Thanks for the site. Didn't know about that one.
And no, I don't need an optical drive. Didn't even think about avoiding it, though since my previous builds have always included one. That they were built more than 5 years ago might be an indication of why. Thanks for the catch, though.
My simulations are likely going to be often heavy on the RAM, so you're right that I might benefit from a faster speed. Not sure how much difference I would notice, but some you gotta just guess...
