Question Desperate for help :(
rudibryson
13
So I have a Linksys WRT32X and open reach modem. This all works fine on the plusnet fibre network. However when I run into SKY fibre I cannot get it to work at all.
I have searched online but cannot see anything that helps me .
I have got to the stage where I have extracted the password and username using wireshark .
I have entered this into the router settings page.
Restarted everything and it just wont connect.
Again I can replace the password and username with the plusnet line and it connects straight away .
Any help would be greatly appreciated .
rudibryson
13
Thank very much , however I am slightly embarrassed to ask but how do i do that ? I have tried googling it before asking again, however I can find no help. I sense I am nearly there .
Thank You
rudibryson
13
I cannot remember how to find the MAC address in the Sky modem. Is that the bit you are struggling with? If yes do you have the model number.
I think i will have the MAC address, I can confirm later, but its where to put it. Does this go into the router or the open reach modem ? I do not know how to access any modem settings , i can log into the router with no problems though
