DESPERATELY IN NEED OF HELP!!!
Jennifer
58
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Im having trouble installing Directx Eradicator and was wondering how you
would re-register dlls.
G
Guest
Guest
If the dll name is Test.dll, then
Go to Start/Run and type in:
regsvr32 Test.dll
click OK
"Jennifer" <Jennifer@discussions.microsoft.com> wrote in message
news:B91ADE27-F84C-4864-BDEC-24C53D4A5009@microsoft.com...
G
Guest
Guest
Jennifer, Go to Start/Run, and type each separately, followed by
clicking OK:
regsvr32 xxxx.dll Just insert the actual dll in the xxxx.dll
spot.
After each time you click OK, you should get a dialogue box notifying you
that your dll has been registered successfully.
After registering all dlls, reboot, and see whether that has fixed the
problem.
Jennifer
58
> clicking OK:
> spot.
> problem.
> Well I did what you told me but it just said the specified module could not be found
G
Guest
Guest
Then we need more information Jennifer.
What error message(s) are you getting when you try to install the 'risky'
DirectX Eradicator?
Which DLL are you trying to re-register?
When you downloaded (and extracted) the zip file did you carefully read the
Readme.txt file and follow the instructions carefully for YOUR operating
system?
news:BCDD1826-81F0-481A-8C4F-1576B0240A65@microsoft.com...
>> > I'm having trouble installing DirectX Eradicator and was wondering how
>> > you
>> not be found
Jennifer
58
> DirectX Eradicator?
> system?
> >> > you
> >> not be found
It says..."The application has failed to start because DSOUND.dll was not
found. RE-installing the application may fix this problem." It says the same
thing for DDRAW.dll. and for nview.dll it says "Error loading nview.dll. The
specified module could not be found and all this happened after after the
installation rebooted my comp.
G
Guest
Guest
Error message stating that the module could not be found indicates just that
it could not be found in the search path. It MAY or may NOT be on the
computer. Try Start/Search and enter the names of the dll's and see if you
can find them anywhere on your drive. If you DO find them, copy them into
your windows folder and try again.
HTH,
G
Guest
Guest
DirectX is not my area of expertise, so I am going to assume that the reason
you installed DirectX Eradicator was so you could uninstall DirectX before
doing a re-install. If true, have you considered trying to download/install
DirectX - even with the error messages you are seeing?
http://www.microsoft.com/windows/directx/default.aspx
Also, there is a diagnostic that will check/validate files like ddraw.dll.
You can download a trial version and see if you can provide us with more
information after running it. As you may know, sometimes these trial
versions have limited ability to fix the problems it finds. I.E., they like
to tease us to get out the ol' credit card. Can you blame them?
Anyway, you can download PC Bug Doctor at:
http://www.all-day-pa.com/
Good luck.
news:21F6C101-9252-44A0-9FE5-D041120733CA@microsoft.com...
>> DirectX Eradicator?
>> the
>> system?
>> >> > how
>> >> > you
>> >> could
>> >> not be found
> same
> The
> specified module could not be found and all this happened after the
