SoleSurvivor111 :
It seems like ever since i got my toshiba 2tb drive it was always slow. I would always get annoyed and move the game to the ssd my friend who has only one hdd loads way faster than mine i try defragging takes abnormally long and i suspect it is about to kick the bucket What should i do?
Apples and Oranges comparisons here.
First a SSD by it mere design is SMALLER and FASTER than the 2TB Mechanical design, so yeah things will 'load way faster'.
Second, 2 TERAbytes of data is ALOT to 'defrag' (which hasn't really solved things in a decade, your thinking back with XP days) so YES will take a "abnormally long time" in comparison to other things.
Third "my friend has only one hdd loads way faster" is relative, is he running a i5 6xxx CPU on the current chipset while your poking along on your A-8 APU based PC? BIG DIFFERENCES here that has NOTHING to do with the HDD but does impact greatly "loads way faster".
Unless your friend has the EXACT same setup (every piece) and setup EXACTLY the same way as yours (configuration) and you sat with your watch and actually TIMED his system to yours, THEN you can make some of these claims and narrow down what to look into as 'the problem'. Otherwise it is just 'perception', and I would suggest what you should have, as you have a SSD, is the OS on the SSD, the games installed to the 2TB (as we all have setup) and if there is ONE or TWO specific games you want to see 'faster load screens' then plop them to the SSD.
REMEMBER a SSD SLOW DOWN MORE AND MORE it is FILLED UP. The closer you get to 100% full, the SLOWER it gets (even SLOWER than a HDD). So make sure your not filling up the SSD.
