Destiny 2 running signifigantly slower after upgrading cpu
Sep 1, 2018
4
Before, i used to use an AMD-FX 4300. I overclocked it to 4.1ghz. I used to get a good 85 fps most of the time.
I recently upgraded my CPU and cooling solution. I now use an AMD-FX 8350 overclocked to 4.3Ghz. The cooling is now watercooled, being coolermaster's Masterliquid ML240L RGB.
Im still using the same GPU, a GTX-1050ti, but now i am getting random frame drops to 20-30fps even with signifigantly lowered settings.
PSU is a corsair 650w psu, motherboard is 760GM-p23
Any advice?
Sep 1, 2018
4
Is there any way i can get it to not throttle without buying a new motherboard?
bignastyid
You could try underclocking and undervolting the cpu.
Sep 1, 2018
4
What would be a sensible underclock/overvoltage?
Sep 1, 2018
4
Okay, the issue resolved itself after i managed to escape from a boot loop (I'm just as lost as you). Thanks for the help, and can some staff please lock the thread?
