"Device Connect" sound
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Is there a way to selectively turn off the "device connect" sound in
Windows XP? I like the notifications; however I have a palm that sets
off the sound each time it syncs. Actually it sets off three sounds:
connect (sync mode), disconnect (sync mode), connect (non-sync mode).
Needless to say, it is a bit annoying.
Thanks!
Carlos
Did you try Control Panel, Sound?
> Thanks!
> Carlos
That only allows to turn on and off the sound for all connect events,
not for a particular device.
Yep, a connect is a connect.
