I am running a Linksys MX4000 router, all has been working fine until some recent strange behaviour. I noticed that some laptops and my firestick had no connectivity. When I check the settings for each device they are connected to the correct SSID but they are connected on the range 192.168.1.x - my network is configured to use 192.168.0.x with corresponding DHCP also configured to use a range of this:
There is only one router transmitting the SSID which the devices are connected to so how or why are they connecting using the incorrect address range?
I've tried the "forget" wifi network on the concerned devices, rebooting and then re-entering wifi passwords but they just reconnect to the wrong range again. I should note that I do also have devices connected via DHCP and are assigned address from the correct range.
I am really confused and don't know what else to try. Any ideas?
Thanks.
Thanks.
