Hello,
I am trying to build a computer for the first time. The components I have are:
_DG31PR motherboard
_Intel Celeron SL9XP 1.6 GHz
_2x 1GB DDR2 PC2-6400
_ 680w power supply (cheap apower ak series)
No hard drive, I want to run Ubuntu on a usb drive.
When I start the power supply, the led of the motherboard turns on, the cpu fan starts and stops after 2 seconds. After, nothing happens. The led stays on. No signal is on the screen. If I press the start button, the cpu fan starts during 2 seconds and stops after.
I have performed all the regular verifications for troubleshooting first start issue: reseat memory, remove and replace the battery, checked the power supply connections, reseated the cpu. Nothing works.
The motherboard does not makes any beep. If I remove the memory it makes three beeps, which is normal.
I have read the motherboard manual but I cannot figure out what is wrong.
Do you have any idea of what could be the issue?
_DG31PR motherboard
