Dg41rq No display while processor fan attached
DeepTech
Commendable
Feb 15, 2016
i have Intel Dg41rq Mother board for repairing .:heink:
No display while processor fan attached when i remove processor fan it display:??: and every thing work Fine but when i attach Processor Fan no display no beep just motherboar led on and fan running ,
in starting it was not working only led on and fan runs , then i installed bios from bios chip no fix then i installed bios again , then i check processor not heat up without fan then i fix this issue now it not display when i attached processor fan. without processor fan it works fine please i also check with other fans but its not fan issue fan work fine with other motherboard , please answer
Yes; the fan will run at full speed and you may need to disable the CPU fan failure (or whatever Intel calls it) detection to prevent the system from stopping at POST.
I know its motherboard issue , i dont want to buy new motherboard , i can buy ddr3 motherboard in $25 , but i need solution for this motherboard , is there any option to connect processor fan with external connector or something , wait i found something hope it will work , i will try this ,,,,, Let;s see
