[SOLVED] DH61H0 Problems
Feb 19, 2019
I have two CPUs, an HP Compaq 6200 pro sff with Intel core I5-2400, and another that has a DH61H0 motherboard, with Intel pentium g630, I wanted to change the processors between the cpus since I saw that they are compatible, in the hp it works perfectly , however in the DH61H0 does not work the i5, when I start it comes out that the processor is not compatible and it is simply turned off, I thought it could be a BIOS error and I never update it, update it until the last version that the page of the manufacturer leaves me, which is the 2012, try with the 2018 but does not let me do it, throws me an error and does not update, would like to change the processors, any ideas?
That board does not support the i5-2400, only the i5-2400S model, since it only supports a max TDP of 65W. The i5-2400 is a 95W processor.
thanks for the reply, What processor do you recommend with a GT 750 TI, or should I change the motherboard? and keep the I5 2400
