Hi all,
Bit of a dilemma I've found myself if after a couple weeks of tinkering with upgrades on an old rig.
I recently decided to try upgrading some components on a factory-built Lenovo H520s desktop.
I replaced the PSU (new EVGA 600W; tested and working properly) and GPU (new Geforce GTX 1060). But upon discovering that the Lenovo factory mobos had zero BIOS updates (and thus wouldn't support my new GPU), I decided to purchase a refurbished mobo (the Asus P8H67-M Pro) on ebay, since my research had led me to believe that this mobo would: 1) be compatible with the GTX 1060, and 2) fit the Lenovo's CPU (i7 3770) and DDR3 Ram (2x4GB Samsung PC3-12800 DDR3-1600MHz).
After installing everything, I've run into a recurring booting issue. When powered on, the system starts up for ~1sec before shutting down and restarting. It'll then cycle on/off indefinitely until the power is cut. The system wont even POST, and I can't enter the BIOS.
I was worried about a bad mobo, PSU issues, CPU compatibility issues, etc. I disconnected everything from the mobo except the CPU and CPU fan, then powered on again. This time, the system remained on (w/ just a black screen, b/c no RAM installed). When I then plugged the RAM back in, the on/off cycling started again.
So my question is: Is this evidence for a singular problem (i.e., RAM is incompatible and thus not allowing startup)? Or could there still be multiple sources for this problem (e.g., still possibly a CPU or mobo issue)?
Research elsewhere has led me to think that either the mobo BIOS may not be updated (which may be preventing compatibility with my current RAM). Or I may just need different RAM (regardless of the mobo BIOS version). I've seen at least one other post with a related issue, where the user resolved the problem by ordering/installing a new, updated BIOS chip. But just wanted to make sure I'm diagnosing the problem correctly and not missing anything before purchasing additional parts.
Sorry for the length explanation, but thanks in advance for any and all help! Happy to provide other details/specs if helpful.
