I have been seeing significant decrease in DL speeds recently thus did a diagnostics test from my Intel Gigabit Card Diagnostic test.: Test Cable Connections and Frequency Response. Results shown as follows:
Cable Offline Test
Poor quality cable detected
Possible causes: Faulty cable, faulty
connector, or a speed/duplex mismatch.
Verify that the speed/duplex setting on
the switch/hub is configured for auto-negotiation.
Test details
Cable Quality:
Low
The test detected a bad connection.
Distance to problem: 20 meters.
Is this accurate? i'm figuring 20m is the actual length of the Cat 5e cable so could it be that there is a problem with the RJ 45 connector at the end of my wire which is connected to the router? And when it says 20m, is it 20m from my router or 20m from my desktop?
Can someone else try this test and let me know if it shows the same result? TY in advance.
Cable Offline Test
Test details
Cable Quality:
Low
