Dialog Boxes Too Small
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
After a complete re-install of XP Pro and all my programs,
hardware and computer settings, several of the dialog
boxes are too small to show the complete set of buttons
and selections. For instance, I can't select photo paper
in my HP printer as the selection is out of sight behind
the right edge of the box. Is there a way to resize these
boxes.
G
Guest
Guest
> boxes.
Are you using a setting other than "normal (96 DPI)" in Display Properties>
Settings> Advanced>General> Display? Or perhaps have changed from Normal to
Large fonts in Display> Appearance? Or using accessibility options?
The reason I ask, some windows are hard coded in size. They do not resize
to accommodate the preferred font size. Text and buttons will be cut off.
There is no way to fix this except returning to default settings. Not
always desirable. With the popular increase in the size of monitors, text
gets smaller and smaller. It's not user friendly if adjusting settings for
readability renders interactive windows useless.
Would suggest writing tech support for the printer to inform them about
this inconvenience as well.
Sharon F
MS-MVP ~ Windows Shell/User
G
Guest
Guest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G
Guest
Guest
Changing to thedefault setting fixed it, thank you very
much. I had tried all sorts of combinations but missed
that one. I appreciate your help, jmh
>-----Original Message-----
programs,
paper
behind
these
>> boxes.
Display Properties>
They do not resize
will be cut off.
settings. Not
of monitors, text
inform them about
>Sharon F
G
Guest
Guest
On Sat, 5 Mar 2005 18:40:35 -0800, anonymous@discussions.microsoft.com
You're most welcome.
Sharon F
Similar threads
