[SOLVED] Did my power supply die while I was making some cleaning?
MrSnipyCat
16
Today I decided to clean the dust inside my PC, everything went fine and then I put it all back together.
When I turned in my PC tho it would turn everything on for a sec fans would also spin for a sec and then everything turned off and it would repeat this loop forever.
I noticed the CPU debug led would turn on each time the PC would turn on so I opened it up but everything was fine , it was correctly placed and it didn't have any bent pins, so I decided to test the power supply and basically this happened:
As you can see when I turned it on the fan would do like a quarter spin every sec but when I turned it off it actually started spinning for a few seconds.
After the test i opened the PSU up and cleaned up the huge chunks of dust that were inside, but it still behaves the same way
Did my PSU just die? 😱
