Difference and can i use either? PC3- 10600 or PC3 - 12800
I don't know where you have seen that, but it is rubbish.
Rated speeds are as I wrote in the previous post.
Your CPU supports DDR3 1333/1600, so choose PC3-12800. This is DDR3-1600.
I should also mention that you should be using a kit with 2 matched dimms.
The CPU has a dual channel memory controller and making use of this is more important than the difference between DDR3-1333 and...
I see some ram saying either
PC3 - 8GB 10600 1600mhz
PC3 - 8GB 12800 1600mhz
Just wanted to know the difference
My CPU is i7 3770
The CPU has a dual channel memory controller and making use of this is more important than the difference between DDR3-1333 and DDR3-1600.
Maximum bandwidth:
1 x dimm DDR3-1333 = 10.7 GB/s.
1 x dimm DDR3-1600 = 12.8 GB/s
2 x dimm DDR3-1333 = 21.3 GB/s
2 x dimm DDR3-1600 = 25.6 GB/s.
