Question Difference between 1080p 144hz Monitors
Hypoltan
234
There are many 1080p 144hz monitors out there, and I am in the process of choosing which one to get. There are the "better" ones like the BenQ Zowie XL2411p at $245 and the "budget" ones like the Acer GN246HL. I am just wondering what the difference between these monitors are, any special features I am missing, even with monitors in the same price range like the ViewSonic XG2401 and Acer GN246HL.
Lastly, which monitor would be the best to fit price and features for around $200?
The main difference is the input time I am pretty sure. Some are 5ms, some may be 6, some 10, it all depends. The ones you listed are all 1ms. (not much of a difference between 1 and 5 to most people anyways)
So i mean.. Go for whatever looks nicest I guess?
Not sure, seems to be a wide price range for 1 ms monitors too.
Well, it's mainly based on what the manufacture wants to sell it. Some monitors have Freesync and Gsync which can be paired with an Nvidea or AMD GPU and basically works as a built in Vsync without the terrible input lag
Other than that, the manufacture can really sell it for whatever they want
