Difference between 1600 MHz and 2400MHz?
Trying to establish maximum frames per second while running a core i9 3960x with a Gtx 780ti or an SLI setup and then trying to see what maximum frame rate you can achieve.
In real world the difference would be between a 1600 and 2400 RAm of about 2-3 fps if you're real lucky too that is.
What sort of benchmarks?
Thanks
