Difference between 3570 and 3570K?
TheSpaceCowboy
8
i5 3570: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115233&Tpk=3570
i5 3570K: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504&Tpk=3570k
So I was looking at the difference between these two processors above, and I'm still a little confused on what the differences are.
They are the same price, but from what I've seen so far, the 3570k seems to do and have everything the 3570 does, and more. Is that correct?
The only difference I see is the integrated graphics, and that does not matter much to me as I am purchasing a graphics card and do not plan on using the processor's graphics.
Why would one purchase the 3570 instead of the 3570K? If somebody could please help me out with the differences, it'd be really helpful.
Thanks, Arron
"I hope you know that 3570k has unlocked multiplier which makes it is more overclockable than 3570."
Well, thats my point, I was only wondering if there was any reason anybody would pay the same price for a 3570 if the 3570k does everything that CPU does and more.
It's kind of stupid though. 3570 should be 5 to 10 dollar cheaper than K version.
That's horrible advice!You should not overclock until you learn more.First of all you do not overclock on a stock cooler. :pfff:
