DIfference between 3rd generation i7 and 4th generation i5
blackbird123
73
Hi, I am trying to decide whether I should buy the 3rd generation i7 or the 4th generation i5 and wondering what the differences are?
Thanks
"These are facts"!? What in the world are you talking about? I think you got confused between laptop and desktop processors.
An i3 is a dual core with hyperthreading. An i5 is a quad core without hyperthreading, and an i7 is a quad core with it. This is talking about the normal, desktop processors only, not xeons (6-8 cores), extreme edition chips (4-6, hypertheading), or...
What's this being used for? If it's gaming then heed the following:
1) An i7 is NO better than an i5 for gaming - the only difference is that the i7 has hyperthreading, which doesn't affect games barely at all.
2) If you're going to be overclocking, Ivy Bridge (3rd gen) is actually faster than Haswell (4th gen). At stock speeds, Haswell is faster.
There is a serious distinction between the i5 and i7. Every intel i3, i5, and i7 chips have hyperthreading. An i5 has two cores, with 4-way processing. An i7 is QUADCORE with 8-way processing. So an i7 is a much better choice for gaming or for any program that can utilize four cores of a processor. I'm not where you got your information but these are facts.
An i3 is a dual core with hyperthreading. An i5 is a quad core without hyperthreading, and an i7 is a quad core with it. This is talking about the normal, desktop processors only, not xeons (6-8 cores), extreme edition chips (4-6, hypertheading), or laptop processors.. all of which, including the i7s, are dual core or less. (not counting the rare "QM" i7s - the ONLY quad core laptop processors intel makes.)
Next time you try to tell someone they're wrong, make sure you're right first - even if you were talking just about laptop processors, you'd be close (i3s and i5s are both dual core with hyperthreading) but not right (most laptop i7s are still dual cores with hyperthreading, not quad cores like you claim they all are.).
i-3 with hyperthreading. i5-with turbo boost, i7 with hyperthreading and turbo boost
