Difference between a 2GB and 3GB Graphics Card?
xxdanxs
69
I am thinking about buying this graphics card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130810&cm_mmc=SNC-YouTube-_-NETV-_-uQUhfhVw-L4-_-14-130-810
My only concern is that it is only 2 GB. Other video cards such as the Radeon 7950 and 7970 come in 3GB. What is the difference? Do the 3GB ones perform much better than the 2Gb one? Will this make a major difference when playing games like Battlefield 3 and Skyrim? Also, will the 2GB model still be powerful enough to run games coming out later this year like Grand Theft Auto 5 and Battlefield 4?
1GB.
No.
Depends on resolution. The higher it is, the differences between 3GB VRAM and 2GB VRAM will become more apparent. The difference is minor.
Yes; I think so. Don't quote me. They're not out yet so I can only make an educated guess.
1GB.
No.
If you are going with a surround setup (3x monitors) or have a 2560x1440 monitor I would consider stepping up to the 3 GB model. For 1080p, the 2 GB will be fine.
It's not like a huge price difference anways (<$50). For example, due to rebate tiers I found a same model 660 (non TI) with 3 GB for only $5 more than the 2 GB on Newegg.
Also do note, I suspect we will see a price break in the current 660/670 series very soon (2-3 weeks, total guess) due to the release of the 7xx series. It's funny because currently some 670 FTW are priced higher than 770s.
