S sharksfin Reputable Jan 10, 2015 48 0 4,530 Mar 25, 2016 #1 What's the difference between ASRock Z170A-X1 ATX LGA1151 Motherboard (Z170A-X1) and ASRock Z170A-X1/3.1 ATX LGA1151 Motherboard (Z170A-X1/3.1)?
Solution Dark Lord of Tech Mar 25, 2016 USB 3.1 spec was added. They did the same thing to the Z97 A awhile back. Asus Z97-A/USB 3.1
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Mar 25, 2016 Solution #2 USB 3.1 spec was added. They did the same thing to the Z97 A awhile back. Asus Z97-A/USB 3.1 Upvote 0 Downvote Solution
S sharksfin Reputable Jan 10, 2015 48 0 4,530 Mar 27, 2016 #3 Is that the only difference? Upvote 0 Downvote
S sharksfin Reputable Jan 10, 2015 48 0 4,530 Mar 27, 2016 #4 I looked at http://www.asrock.com/mb/Intel/Z170A-X13.1/?cat=Specifications and http://www.asrock.com/mb/Intel/Z170A-X1/?cat=Specifications side by side using Opera browser, and I Ctrl-Tabbed as I scrolled down. There's two things that the 3.1" motherboard has that the non-3.1 doesn't: 1 x USB 3.1 Type-A Port (10 Gb/s) 1 x USB 3.1 Type-C Port (10 Gb/s). Upvote 0 Downvote
A ArtPog Admirable Sep 17, 2014 2,951 3 8,965 Mar 28, 2016 #5 Does anyone know the precise dimensions (L x W) of the ASRock Z170A-X1/3.1 MB? Thanks. Upvote 0 Downvote
