Difference between AsusP8Z77-V LX and Asus P8Z77-V LX2? PLEASE ANSWER FAST!!!
Zoltan782
Commendable
Jun 11, 2016
So I was going to buy the P8Z77-V LX but then it was out of stock and i also found the P8Z77-v LX2 and i was wondering if they were the same or what the differences were. Which one is better? DO they both fit the same things? IM going to use the intel i5 3570k and the Zotac GeForce GTX 750ti Gpu? do they fit in both motherboards? also do these fit in both motherboards?==== DDR3 ram, Western Digital 1tb HDD Blue, Adta 240Gb SSD sata 3? Sorry for so many questions but please help this is going to be the first pc i build and i want to make sure everything fits and is correct.
Thanks
The LX2 is an upgraded version of the rather poorly reviewed LX. The LX2 gets much better reviews, even from users :)
You should be fine just make sure the manufacturer of the ram you want to get lists the board as being compatible.
