difference between Atheros, Broadcom and Intel
shaun88
279
i need to re-install my Wi-Fi driver on my netbook Acer D270, on their website I have three to choose from: Atheros, Broadcom and Intel
the download sizes are
Atheros 44.8mb
Broadcom 78.7mb
Intel 139mb
is one better than the other? which should I choose?
thanks
Those are different chip manufacturers and thus each driver is for a different wireless card.
If your laptop has a very easy to take off access panel on the bottom, take it off and find the small wireless card that has a black and white small antenna cable going to it.
Will look something like this: http://cdn.i.haymarket.net.au/Utils/ImageResizer.ashx?n=http%3A%2F%2Fi.haymarket.net.au%2FFeatures%2F20120305045723_Capture.JPG&h=480&w=640
You can hopefull find the type on a sticker/label on that.
Otherwise you can install each one individually and see if it works, if it is ot the right driver then it will tell you durring install.
