G Guest Guest Apr 28, 2014 #1 Can someone please tell me the difference between a normal backlit keyboard a RGB backlit keyboard?
Solution mickypheonix Apr 28, 2014 Hi CaptainGunny a normal backlit keyboard is set to one color a RGB (Red Green Blue ) keyboard can change multiple colors
mickypheonix Honorable Mar 9, 2014 4,051 1 10,960 Apr 28, 2014 Solution #2 Hi CaptainGunny a normal backlit keyboard is set to one color a RGB (Red Green Blue ) keyboard can change multiple colors Upvote 0 Downvote Solution
G Guest Guest Apr 28, 2014 #3 mickypheonix : Hi CaptainGunny a normal backlit keyboard is set to one color a RGB (Red Green Blue ) keyboard can change multiple colors Thanks 😀 Upvote 0 Downvote
mickypheonix Honorable Mar 9, 2014 4,051 1 10,960 Apr 28, 2014 #4 you are welcome m8 , all the best Upvote 0 Downvote
