Difference Between Delete and Delete SubFolders and Files
Rob
1,573
Archived from groups: microsoft.public.win2000.security (More info?)
Can someone tell me the Difference Between Delete and Delete SubFolders and
Files as it appears in the special permissions?
The link below is for XP Pro but almost all applies about special
permissions. There is a subtle difference as shown in the descriptions I
pasted from the link. Users who have Delete Subfolders and Files
permission on the parent folder will be able to delete files and subfolders
in the parent folder even if they do not have delete permissions on that
file/subfolder. The delete permission is more granular and would be used to
give/deny user delete permission if they do not have Delete Subfolders and
Files permission on the parent folder. Now if the user has explicit allow
for Delete Subfolders and Files on the parent and then explicit deny Delete
to a file/subfolder I am not sure what the effective permission would be and
that should be tested. My guess is that the user would be denied delete
since that permission is "closer" to the file/folder. -- Steve
http://support.microsoft.com/default.aspx?scid=kb;EN-US;308419
The Delete Subfolders and Files permission applies only to folders and
allows or denies the user from deleting subfolders and files, even if the
Delete permission is not granted on the subfolder or file.
Delete
The Delete permission allows or denies the user from deleting the file or
folder. If you do not have a Delete permission on a file or folder, you can
delete the file or folder if you are granted Delete Subfolders and Files
permissions on the parent folder.
"Rob" <Rob@discussions.microsoft.com> wrote in message
news:F2220413-DBE9-42EC-B25F-1AD52A0C5D7C@microsoft.com...
> and
In news:F2220413-DBE9-42EC-B25F-1AD52A0C5D7C@microsoft.com,
Rob <Rob@discussions.microsoft.com> had this to say:
My reply is at the bottom of your sent message:
> SubFolders and Files as it appears in the special permissions?
Delete they can delete the file, delete subfolders and files means that they
can delete files and folders within that folder itself.
Permissions:
http://www.comptechdoc.org/os/windows/win2k/win2kpermissions.html
For entertainment:
Advanced Folder Level Permissions:
http://www.uwec.edu/help/Win00/perm-advfolder.htm
Windows 2000: Working with Folder Level Permissions, UWEC:
http://www.uwec.edu/help/Win00/perm-folder.htm
Galen
"But there are always some lunatics about. It would be a dull world
without them."
Sherlock Holmes
Checking the "applies to this object only" box or whatever it is called seems
to get around that
> Delete
> > and
