Difference between digital uv and ordinary uv filter
jgh64
Hello,should I pay more for digital uv filter or just buy the ordinary one say B+W 010 for my digital Camera.
Thanx.JGH
There is no difference between the filters as far as filtering is concerned. A UV filter is a UV filter. It is the mount (diameter) that may be different depending on which size lens you mount it on.
The glass quality may differ from manufacturer to manufacturer. Prices too.
